vtec problem
Old Jul 4, 2003 | 10:06 AM
LIL_G's Avatar
Default vtec problem
i got a b16 and the redline is 8200 but it wont even go that high i checked the filter in the silinoid it good maybe its not getting enough oil but there is plenty of oil in the pan. my valves tick but i think they just need to be adjusted i need some suggestions maybe once i adjust the valves it will rev that high i dont know.
Old Jul 4, 2003 | 10:14 AM
99B16Si's Avatar
so whats the problem??? vtec wont engage or your car wont rev all the way to redline??? what does it do when it cuts off??? give more details and then maybe someone can help
Old Jul 4, 2003 | 07:55 PM
spoonfed's Avatar
Tha numba one stunna
what ecu are you running (thats the computer under the kick panel on the passenger side)
... content in sig not work friendly
Old Jul 5, 2003 | 06:58 AM
NChatch's Avatar
i stepped on my weiner!
it could be an automatic ecu
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Jul 5, 2003 | 02:59 PM
KJ's Avatar
KJ
bored at work
probably auto ecu. post up the complete serial number on the side of the ecu and I'll tell you.
Old Jul 7, 2003 | 10:17 AM
LIL_G's Avatar
the vtec wont engage. but if i run a hot wire to the cylinoid it will turn on, so i made a hot wire with a switch and tried it out on the road and it workes but im only getting to about 7600. so i dont know if its the computer or a short. i looked at the computer when turn the key and its giving me codes but i dont understand them. now on the stalling part it will only do it every once and a while like the distributer is losing power cause after it will stall ill take a plug wire off and put it next to the distributer and i see no spark then eventually there will be spark and it will start. ask me more if you need to thanks
Old Jul 7, 2003 | 10:42 AM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
ls ecu maybe?
tamparacing.com
Old Jul 8, 2003 | 10:05 AM
TEP-ITR-REX's Avatar
IF vtec is not working then the redline drops. Putting it on a switch is the wrong way to fix it cause the low redline is still there and theres no fuel to help the hich lifting lobes. Try to see if your nock sensor is hooked up and make sure your oil pressure switch is working as well as the vtec sylnoid.. If one of those is out then vtec is screwed...You can check your ecu but dont assume the worst..
I drive a HONDA so what!! My GF is BANGIN must be the MOTOR...
