Ls Problem!!!!
Old May 31, 2003 | 12:50 PM
MOORESPEED's Avatar
When you need it most
Unhappy Ls Problem!!!!
Car will start, idles low and when you rev it up and let off the gas it almost stalls. When you drive the car it will run for a few seconds and then TOTALLY SHUT OFF. When you try to start it again it sounds like its bubbling up and then puffs out some smoke through the intake. PLEASE HELP
This can of whoop ass dont need no refill
M.S.R.
Old May 31, 2003 | 02:24 PM
98hciv's Avatar
ls/vtec turbo on the way!
sounds like your timing is off.
Old May 31, 2003 | 02:46 PM
MOORESPEED's Avatar
I have done the timing several times already. Any other ideas?
M.S.R.
Old May 31, 2003 | 02:58 PM
S.crix's Avatar
d : - L ......
check the ecu for any codes,it may be a sensor unpluged
check the map sensor for vacuum
check valve lash adjustment (make sure there not too tight)
check timing with a timing light?.............
u GUYS can SUCK my BALLS
