nitrous works quick question
Old May 24, 2003 | 11:58 AM
bart's Avatar
h22 hatch
Default nitrous works quick question
im installing nitrous works on my h22a.ok i got everything hooked up but the fuel line for the solnied. so where do i hook it up at.
dead once again
Old May 24, 2003 | 05:46 PM
NChatch's Avatar
i stepped on my weiner!
use some type of "t" fitting from ACE hardware, or autozone, brass or plastic, cut the fule line to the fuel rail in half, insert the "t" and branch it of to your solinoid, you may need a NPT fitting depending if you have steel braided line, running to it or just a rubber hose with a fitting on the end.
about 5.00 bucks worth of parts
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old May 25, 2003 | 05:45 AM
bart's Avatar
h22 hatch
so cut the fuel line that goes to the fuel pressure regilater?
dead once again
Old May 27, 2003 | 11:00 AM
civicjunkie's Avatar
it just kinda went BOOOMM
hey you gotta get a T fitting and tap it into the line. dont "cut" anything...that's bad...take it to a pro if you don't know how to do it. find a local nitrous dealer and order a t fitting. Then take it somewhere and they'll do it for you. But don't cut anything.
........settling for another D series... oh well.
Old May 27, 2003 | 11:34 AM
01Ls-RTeg's Avatar
Genius v3.015
no the line that runs from the fuel rail to the fuel filter
Yes, I do talk to myself, it is the only way I can have intelligent conversations.
