b16 revving to 4k????
Old May 12, 2003 | 08:21 PM
  #21 (permalink)
slovvcrx's Avatar
i know how you feel man
Old May 12, 2003 | 08:26 PM
  #22 (permalink)
0 0 0's Avatar
are you having the same problem???
Old May 12, 2003 | 08:27 PM
  #23 (permalink)
slovvcrx's Avatar
i had the problem sort of and i replaced my dizzyt and it was fine
Old May 15, 2003 | 10:27 PM
  #24 (permalink)
0 0 0's Avatar
any more suggestions????
Old May 16, 2003 | 07:55 AM
  #27 (permalink)
0 0 0's Avatar
but the code 4 is in the dist. i dont know....fuk it,im gonna try and get a dist...
Old May 16, 2003 | 05:28 PM
  #28 (permalink)
Jay's Avatar
Jay
Janky
i just put a d16zc motor in my girls 91 crx finally got the wiring conversation an hooked it up.
when i hit like 6 grand it acts like the clutch just let go or it hit some type of limiter almost same thing im trying to figure out what the hell it is
you get any more info on this let me know
Aim: o JankyJ o
http://jankycrew.com
Old May 16, 2003 | 07:22 PM
  #29 (permalink)
Sunrise City Rider's Avatar
WHAT!?! OK!......
Originally posted by 0 0 0
what exactly does the crank position sensor do and if its bad what does it limit?would it make my car not rev out???,misfire???
The Crank Position Sensor is used to adjust timing as the engine's load changes...The different MAPs are stored in the ECU and uses the Crank Position Sensor, plus a few other sensors to select the correct map for the present situation...
A Crank Sensor will hold your Rev Limit down as a safeguard from running too much timing as your RPM rises...
Get any b-series vtec distributor that works and see if that clears up your problem...I believe the #4 code and the REV limitations are directly related...
An obd2 B-series Vtec distributor will require you to change the plug to the pair of obd1 plugs...
Zee
I work too damn Hard...
04 Civic Si
01 Lexus GS300
Old May 17, 2003 | 05:09 PM
  #30 (permalink)
Jay's Avatar
Jay
Janky
i have this exact same problem
i have a d16z6 ina crx i did the obd1 conversion and was still running the si intake mani.
when i changed to the d16z6 mani to day i have this exact same problem as well as it idles like shit there where no changes to the distributor execpt for a new cap and rotor.
Any ideas???
-Jay
Aim: o JankyJ o
