RECALLS On My Civic!! LOL...
Old Apr 13, 2003 | 06:37 PM
styles999's Avatar
Powered ByYo Mommas Mouth
Default RECALLS On My Civic!! LOL...
I was chillin and searchin the web, i ran across a honda recall site and i looked up my civic, i started looking at some of the things, and yeah i had replaced alot of them, lol, just thought it might be amusing.... Here is the Site .... http://www.alldata.com
Bulletins for 1991 Honda Civic Dx Hatchback 1.5L SOHC (D16a6) DPI Model
Safety Recalls
OCT 95
Recall - Front Seat Belt Buckle
General Recalls
JUL 93 Campaign - Ignition Control Module (Igniter) Defect
Service Bulletins
DEC 01 Suspension - Rear Suspension Clunk/Squeak Noise
DEC 00 Wiring Terminal - Repair Instructions
OCT 00 Supplemental Restraint System - Inspection
APR 00 Required Special Tools And Equipment,
MAR 00 Rear Suspension - Clunk Noise
MAR 00 Audio Unit - Warranty Exhange/Out of Warranty Repair
MAR 00 Torque Converter Oil Seal - Installation Tool
DEC 99 Service Publications - Availability & Ordering
MAY 99 Recommended Materials
OCT 98 Interior - KRYTOX(R) Fluid Applications
AUG 98 Special Tool Loan Program
APR 98 Audio Unit - Antitheft Code Labels
APR 98 CV Joint Boot - Band Tool
FEB 98 Engine/Transmission - Hydraulic Lift Truck usage
NOV 97 Cyliner - Head Gasket Leaks.
MAY 97 90-007 - 05/27/97
MAY 97 Brakes - Disc Refinishing Procedure
MAY 97 Tools - Denso HLD-100 Halogen Leak Detector
MAR 97 Body - Minor Paint Finish Repair
MAR 97 Tools - New Fuel Pressure Gauge and Replacement Parts
SEP 96 Tools - Power Steering Pressure Gauge
MAY 96 Radio - Warranty Exchange/Out Of Warranty Repair
MAY 96 Required Special Tools & Equipment
FEB 96 Tools - Belt Tension Gauge Calibration and Repair
JAN 96 Engine - Idle Vibration or 'Click'
JAN 96 Seat Belt - Slow to Retract
JAN 96 Seat Belts - Availability of New Parts
JAN 96 Seat Belts - Warranty Replacement Policy
DEC 95 Radio - Unit Diagnosis
AUG 95 Service Publications and Supplies
JUN 95 A/C - Converting R-12 Systems to R-134a
MAR 95 Radio - Unit Exchange/Repair
JAN 95 A/T - Drive Axle and Wheel Lug Nut Torque Specifications
OCT 94 Alignment - Wear On the Inside Edge of Front Tires
SEP 94 A/T - Remanufacturing Exchange Program
AUG 94 Steering - Wheel Oscillates or Has a Shimmy
AUG 94 Tools - Exacta Code Key Cutter
JAN 94 A/T - No Upshift No Line Pressure After Rebuild
DEC 93 Battery - Testing Procedure
DEC 93 A/T - Starts In Wrong Gear/No Reverse
NOV 93 Body - Moisture Inside Taillight
OCT 93 A/T - Failsafe Modes
OCT 93 A/T - Trouble Codes
FEB 93 Engine - Vapor In Charcoal Canister
FEB 93 Brake - Rear Caliper Rattle
FEB 93 Emissions - Label Replacement Information
JAN 93 Mirror - Wind Noise Near Door Mirror Area
NOV 92 Engine - Vehicle Fails State I/M Emission Test
NOV 92 Tools - Crankshaft Pulley Holder
NOV 92 Window - Noise While Raising or Lowering Window
OCT 92 Seat Belt - Track Seal Torn
OCT 92 PDI - Shipping Wax Removal Update
SEP 92 Exhaust - Noise At Certain Engine Speeds
SEP 92 A/T - Intermittent Electrical Problems
AUG 92 A/T - Bind-Up In 4th Gear
JUN 92 A/T - Noise Going Into or Out Of Reverse
MAY 92 A/C - Odors From Vents
MAY 92 Front Brakes - Squealing Noise
APR 92 Drive Axles - Clicking Noise While Turning
APR 92 Seat Belts - Torn Seal On Track
MAR 92 Radio - Out-of-Warranty Audio Component Repair
MAR 92 Parasitic Draw - Test Clarifications
FEB 92 Engine - Distributor Repair Procedure
FEB 92 Fuel/Emission Notes
FEB 92 Ribbed Belt - Installation Precautions
JAN 92 Engine - Charging System Testing
JAN 92 Windows - Loose, Rattle, Wind Noise & Water Leaks
JAN 92 A/T - 4 Speed Pressure Specifications
DEC 91 Instruments - Lights Flicker
DEC 91 A/T - Transmission Remanufacturing Program
DEC 91 Nose Mask - May Cloud Paint
NOV 91 Interior - Sun Visor Damaged By Seat Belt
NOV 91 A/T - How To Use A Pressure Gauge
NOV 91 Body - Paint Codes
NOV 91 Engine - Occasional Rough Idle
SEP 91 A/T - 4 Speed Identification
SEP 91 A/T - Computer Diagnostics
JUL 91 Accessory Wiring - Damages Fuse Block
JUL 91 ECU Connector - Terminal Removal
JUN 91 Instruments - Trip Meter Stops Registering
JUN 91 Emissions - Underhood Label Replacement Information
JUN 91 Warranty Policy - Assembly/Component Replacement
MAY 91 Engine - Oil Leak Around the Spark Plug Well
APR 91 Mirrors - Door Mirror Vibrates and Rattles
APR 91 Mirrors - Whistling Heard From Either Side
APR 91 Service Bulletin Index Update
APR 91 Service Supplies and Publications
MAR 91 Radio - C.D. Player Exchange Program
MAR 91 Windows - Rear Quarter Window Rattles
FEB 91 Special Tools - Equipment, and Service Manual
FEB 91 Interior - Knee Bolster Cover Won't Close
FEB 91 Engine - Idle Fluctuation Service Tip
FEB 91 Windshield/Headliner - Creaking Noise
DEC 90 Tools - Engine Stand and Adapter Information
DEC 90 Tools - Instructions For New Ball Joint Tool
OCT 90 Radio - Exchange Program
OCT 90 A/T - Engine Vacuum Testing
SEP 90 Windows - Markings Under Certain Lighting Conditions
AUG 90 Tools - Anti-Lock Brake Checker Repair
AUG 90 Cigarette Lighter - Switching Precautions
AUG 90 Radio - Noise/Interference Service Tip
JUL 90 Muffler - Revised Warranty
JUL 90 Recycled R12 - Storage Tips
JUN 90 R12 Refrigerant - Recovery/Recycling Update
MAR 90 Water Pump - Coolant Weepage
FEB 90 A/T - Choosing the Right ATF
OCT 89 A/T - Math Part II
SEP 89 A/T - Twenty Steps To Successful Repairs
AUG 89 A/T - Math Formulas Part I
FEB 89 Tools - Check Mainshaft End Play
DEC 88 Paint - PDI Inspection
SEP 87 A/T - Front Bushing Wear
AUG 87 A/T - Slipping or No-Shift/Metal Sealing Rings
Old Apr 13, 2003 | 08:03 PM
KJ's Avatar
KJ
bored at work
Most of those are techinical bulletines and not recalls.
Old Apr 13, 2003 | 10:24 PM
Hyperwire's Avatar
nibble my chode
i was wondering about the seatbelts, because i dont know of a 4th gen with working seatbelts... including mine... everything works in my car (even the seatbelt lights on the headliner), except the seat belts...
"Faster Than A Speeding Mullet"
Old Apr 14, 2003 | 06:47 AM
Hyperwire's Avatar
nibble my chode
Originally posted by Cronic
Why does it say D16a6 if that's for the 1.5L motor?
damn, good eyes... i didnt even catch that...
Old Apr 14, 2003 | 02:01 PM
styles999's Avatar
yeah that is weird, all i did was copy and paste as far as the d16a6, but the same model is right for my year, i got tired of the headliner light (Can U Say UNPLUG?) lol , and my seatbelts i have relpaced 2 times, now my driver side went out again so forget it, im goin to get seats with a 5 point hopefully
Old Apr 14, 2003 | 02:55 PM
Young,Fablous,&Broke's Avatar
How can you have an August 1987 Bulliten for a 1991 Civic?
Old Apr 14, 2003 | 03:03 PM
Hyperwire's Avatar
nibble my chode
this generation civic and crx was 1988 - 1991, so im assuming that the 1987 reports were a few months after the cars came out... they may have said 1991 civic dx d16a6 (which is actually only in the Si's) but they probably meant all 4th gen (88-91) civics and crxs...
Old Apr 15, 2003 | 04:22 PM
styles999's Avatar
yeah my car looks exactly like yours in the pic, but the 88-91 are pretty much the same, except the engine and suspension's
