Alittle on the warm side
for the past month or so my car has been running alittle hotter then normal. the temp needle sits alittle higher ( not noticable to anyone but me, it's that little ) and my head feels hotter to the touch. so I'v been keeping my eye on it but the other day I got on it alittle to pass some one...ok I floored it to pass someone and within 3 seconds the needle jumped up like an EGT and then fell down soon as I got off the gas, what could cause engine coolant to spike that quickly?? I have a new thermostat and radiator ( with a little dent from my furry frend ). my radiator cap is super old and the rubber plunger deal thats in it is all decraped and torn, could this minor deal cause the car to do that? my other thought, but this is a long shot, is that my header is so freak'n dented up that the exhaust gas does'nt flow out of the motor fast enough and the temp rises. any ideas?
'88 Civic Sedan - Cardinal Metalic Red
153.5 whp AllMotor
www.LHTperformance.net
153.5 whp AllMotor
Guest
Posts: n/a
Radiator cap can cause overheating. My car was doing the same thing, but more noticable. If your cap is leaking pressure, it will cause overheating problems(from what Ive been told). My problem is that my rad fan switch is not functioning properly, it comes on sometimes, but not ALL the time it needs to, causing the car to slightly run warmer.
How long has it been since you flushed the radiator fluid? And replace your cap.
WTB:A clean 90-91 civic hatchback. Red or black or white in color. Good exterior. Looking to spend around $2,000.
the fluid was flushed about 3 months ago when I got the new radiator. I don't think the cap has every been changed.
153.5 whp AllMotor
153.5 whp AllMotor
