Idle problems...
Idle Air Control thats what i thought he meant. yeah usually the screen filter has a tendency to get clogged i guess...
Ive also been informed that air pockets in the coolant passageways can cause this ? weird.
-2003 Ford Mustang
-1986 Toyota Corolla GT-S
-1993 Honda DelSol Si
Toys:
-2003 Honda cr125r
-2003 Honda cr250r
-2003 Ford Mustang
Toys:
-2003 Honda cr125r
-2003 Honda cr250r
What does the iac. look like?....is it the black cylinder behind the t.b.?
-2003 Ford Mustang
Toys:
-2003 Honda cr125r
-2003 Honda cr250r
-2003 Ford Mustang
Toys:
-2003 Honda cr125r
-2003 Honda cr250r
damm josh hvnt realized its gotten worse, when u wer at my house the other day it waz like vvrrmm, --------vrmmmmmm---- vrmmmmm the Yota used to do the same thing till i fixed the idle , mostlikely an idle problem, man Yotas and Das r completely diferent
Don't Text And Drive
IAC is Behind your intake manifold facing the fire wall, located next to the TPS sensor , held on with 2 -12mm bolt
CHeck your PCV valve, the ones at the local parts stores are crap , makes your idle jump like crazy, get it at Honda dealer
