Swapping a DX head with an EX head..worth the trouble ?
Old Mar 13, 2003 | 03:37 PM
civicjunkie's Avatar
it just kinda went BOOOMM
Default Swapping a DX head with an EX head..worth the trouble ?
Okay, so i have q uestion but i may not know how to word it so stick with me on this one.
My friend just swapped a B18 into his civic and still has his old D16y7. I have a civic dx with a stock motor and my friend has an Ex mototr. I've moddified my car a little and im aster then most stock civic ex's. my question is, we've been thinking about swapping the head of off his old motor with the head on my motor giving me the EX head on a DX block. My question is, will this give me higher compression and do anything for my hp or torgque or anything like that ? Will this improve my cars performance and make it fasteror should i just not worry about it. Im afraid im not gonna have some wires or harnessesss i might need so im hoping you guys can help me out. Any websites on this procedure or more imformation would be greatly appreciated. Thanks guys.
Old Mar 13, 2003 | 04:17 PM
spoonfed's Avatar
Tha numba one stunna
you will definitly gain power you have to make either make a vtec controller or swap your ecu but this is cheap and easy do it!!!!!
... content in sig not work friendly
Old Mar 13, 2003 | 06:24 PM
So i don't need to tap an oil line or anything ? i'm getting his ECU.....strictly bolt on huh ? I hope it's as easy as it seems it's gonna be.
........settling for another D series... oh well.
Old Mar 13, 2003 | 06:58 PM
crix's Avatar
:mugen member:
IF this is a vtec head & ECU that you are getting ,then this swap is very easy ..No oil lines needed ...The cylinder head bolts on
& the ECU plugs in ........,All you have to do is run 3 wires for vtec.IF you want any help PM me.....
Old Mar 14, 2003 | 12:26 PM
i-h8mytruck's Avatar
GONZO SHAPED MEMBER
shouldn't he machine the head, very slightly, to make sure that is not warped. He wouldn't want to put that head on start having oil leaks allover.
Did somebody bass tape you?
Old Mar 14, 2003 | 01:05 PM
foesicks's Avatar
Originally posted by RavageEJ6
you do have to drill out an oil line or somthin in the head
not that hard
ding ding wrong answer
SOHC 1.6 VTEC
----CRX DX-----
