Need HELP!Crx Si Oversized Valves
Yeah if you believe what that guy says then you are in for some fun. Don't trust that guy or his work. If you go ahead with Gude don't say you were not warned.
Gracie Barra Clearwater
Originally posted by KJ
Bisi's old motor was a 1.9L, bored and stroked, built by R&D. It was making over 220whp. If you really want to build a fast N/A single cam you'll need to go that route too. I seriously doubt a 1.6L sohc can hit 200whp.
From my recollections from Bisimoto's posts this is what he ran this last season:
displacement: 1530cc's
block: D15B6 and D15B1. Darton sleeves. 78mm bore.
crank: welded. stroke: 80mm. B.E. diameter 45mm
rods: custom aluminum, formerly LS rods. rod length 137mm
R/S: 1.71
pistons: VERY custom. C/R > 18:1
sidedraft dual carbs.
Accel wires
STOCK COIL
denso iridium plugs
Torco synthetic for engine and tranny, not sure about weights.
Honda oil filter
4-1 header
acoustic enhancement chamber.
PS he had RS machine did all of his work. look on the side of his car.
Guest
Posts: n/a
ok when you finish your 10 second trailer queen you call me up and i will race you with my high 11 second daily driver with full interior and ac with power options... i will place 500 bucks on it too... i am that positive that you will not be able to build this car...
-Keith
-Keith
already been done his name is Bisimoto its a crx hf, pro racer, 1.5 SINGLE CAM, N/A ,if you doubt me look in the september 2000 issue of super street all the way in the back. in that issue he was running 12's. All day long All motor. but like you said, " you will not be able to build this car."
