05 CRV Coilovers....
Old Jul 4, 2019 | 08:31 AM
coleon's Avatar
RedNeck Refab.Inc
Exclamation 05 CRV Coilovers....
Been searching for a set of coilovers for my 05 V, slightly used would be cool. Considering new set ranges from 6-700.00 - 1400.00 bucks. Which is F'ing crazy.. But I've found a dozen sets for sale but there all for the older V's (97-01) and newer (07 and up)
Im curious as to what the difference is between the years and why a set from an 97-091 wouldn't fit? Im half tempted to buy a set and try to fit it. Anyway I'm hoping someone has laid eyes on the different years and could shed some light on this...
Any help would be greatly appreciated....
Thanks, Cole
Coleon@gmail.com
And When It Rains.. It Pours..
Roughneck Refab .Inc
Old Jul 4, 2019 | 04:52 PM
Any shock that has the coil spring over the shock is a coilover.
Adjustable coilovers can be adjusted for height.
You may not have to buy another coil spring, since springs rarely wear out.
If the shock compressed distance is the same and the expanded shock distance is the same
and if the bottom mount is the same and if the top mount is the same (do the bolt holes line up?)
and if the pressure to close the shock is the same and if the pressure to open the shock is the same.
then the working part of the shock is the same..........and logically, the shock will interchange.
Some recyclers/junkyards will print out an interchange for you that tells which shocks will interchange with others.
Some shocks will fit several cars.
Let us know what you find out and we will all get smarter.
Dephective
Mazda Tech
Aug 1, 2010 05:27 PM
flubyux2
Mazda Tech
6
Nov 1, 2007 11:36 PM
mranlet
Jul 1, 2004 05:55 PM
sil8ty
Nissan/Infiniti Tech
Jun 4, 2003 07:26 AM
Alan
Jun 22, 2001 09:35 PM
