more tq
What did the b16a block have that it got 143 lb-ft, I've never seen a 1.6l even come close to that. Not doubting, just curious.
Gracie Barra Clearwater
i make 226tq from a stock internal sohc motor
it made a whopping 107tq when it was n/a
1998 Nissan Maxima
88 CRX Si-turbo (d16z6 stock internals) 302hp 251tq- 11.8@123
http://www.cardomain.com/member_page...page_id=259508
1998 Nissan Maxima
I was referring to N/A.
AS for what to do next. Don't do the cams first do them last. Do either the manifold or the header next. Also you need compression to run big cams. With the compression you have with your setup you wouldn't want to run anything bigger than type R cams, not that R cams are bad, for midrange you won't be able to beat them and still gain on the top. The bigger the cam the farther up in the powerband you are going to have to go. Ah, I'm off the point now so I'll quit my rant...
