LOUD Valve Tap
Old Feb 13, 2003 | 07:13 PM
Skunk2 LS's Avatar
Default LOUD Valve Tap
Just installed Crower Stage 2 Cams and Dual valve springs and retainers and now the car has very loud valve tap.
Afriad to drive car.
Any Suggestions on this?
Old Feb 13, 2003 | 07:28 PM
99B16Si's Avatar
Default Re: LOUD Valve Tap
i hope you adjusted your valves. if u didnt i would recommend it asap
Old Feb 13, 2003 | 07:32 PM
Skunk2 LS's Avatar
I plan on doing that tomorow after work.
should that fix my problem.
cause they didnt tap that loud before i changed to the crower valvetrain.
could it be a timing problem?
clearance?
unbroken in springs?
Old Feb 13, 2003 | 07:51 PM
99B16Si's Avatar
whenever u change your valvetrain or cams u need to adjust your valves. adjust them and everything will be fine.
Old Feb 13, 2003 | 08:12 PM
Skunk2 LS's Avatar
apreciate the help
thanks.
