98 integra h22 swap main relay problem...need help please...
ok so here is the run down. I have a 98 integra ls...I swapped a f20b dohc as for ecu I have a p06 w/h22 base map MY MAIN RELAY IN NOT CLICKING ON BUT WHEN I JUMP THE HARNESS I HEAR THE FUEL PUMP KICK ON THEN THE CAR WILL START. I CHECKED MY FUSES,ALL MY GROUNDS AND STILL NO START.........SO I HAD A EXTRA MAIN RELAY INSTALLED IT BUT STILL NO CLICK/CRANK. I HAD TO RELPACE MY IGNITION SWITCH WITH A EG IGNITON DUE TO LOOSING THE KEYS COULD THAT BE A PROBLEM..ALSO I REPLACED THE DASH TO CHANGE INTERIOR TO BLACK..... I AM STARTING TO GET FRUSTRATED ON WHAT IT CAN BE...ANY HELP/TIPS WILL BE GREATLY APPRECIATED THANKS OR YOU CAN TXT ME AT 813 842 9094
Koeo the fuel pump primes?
PUREBRED PERFORMANCE
Fabrication & Tuning Services
813-451-7547 or 813-712-0202
Www.PPETUNED.com <~~ WEBSITE
Curious on honda/acura Ecu Chipping and dyno tuning? Call or visit the website above. Hondata/Neptune/Ectune/Crome Pro. Tuning available for most other systems and platforms as well. DYNOJET
When you say you changed the ignition switch, did you change just the mechanical portion or mechanical/electrical portion?
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
JoKie TuNinG
StricKlyMT
727-510-6301
Take the electrical portion of the switch apart and I bet you will find corroded contacts or arced contacts. Clean them up and put die electric grease on them.
How to replace the ignition switch or troubleshoot (Honda, Acura)
JoKie TuNinG
StricKlyMT
727-510-6301
JoKie TuNinG
StricKlyMT
727-510-6301
ok thanks.... will try that is there any other possibilities? because the car is about 2miles away from where I stay I hate to go back and forth...I NOTICED THE EG IGNITION HAS A EXTRA SLOT (IN THE MIDDLE) FOR A SENSOR COULD THAT BE A PROBLEM..IS THERE A GROUND UNDER THE DASH I SHOULD LOOK FOR?
