95 civic cx w/d16y8 - bogging at low rpms
Old Aug 1, 2012 | 09:45 PM
napR6's Avatar
Default 95 civic cx w/d16y8 - bogging at low rpms (pics up)
Recently bought this car , what a hack job they did. Car is retarded at low rpms. Changed sparks plugs, distributor cap rotor, and timing belt. Will change fuel filter next. Its missing a few sensors and vtech isn't engaging. I have yet to identify which ecu they have and I prob need new wiring.What sensors am I missing? What is the correct.ecu /wiring?Can't seem to upload pics.. will do it tomorrow morning.
Old Aug 2, 2012 | 12:48 AM
97EJ-6's Avatar
Kiss Mi Ras!!!!!!
Maybe off timing
JumpManPm me for any needs for a Honda/Acura/Evo. From tune ups to motor builds TR "Old Skool DA" Member #91Still Jokie!!!!!!!!!
Old Aug 2, 2012 | 03:26 AM
napR6's Avatar
Already adjusted
Old Aug 2, 2012 | 03:32 AM
napR6's Avatar
Ecu is obd1 po8
Which is stock. Is this ecu proper for this conversion?
Old Aug 3, 2012 | 04:13 AM
jdmpineapple's Avatar
call me i can lend a hand 813
410 0923
Old Aug 24, 2012 | 08:19 PM
JDMASFAWK's Avatar
Vtec solenoid not plugged in....
Old Sep 2, 2012 | 06:53 PM
freakasis's Avatar
Sounds like timing. They could have used the wrong cam gear, making the marks look right but actually be off. Check the spark timing using a light. Also, is the check engine light on?
Also, the VTEC solenoid IS wired up. Ignore his^ post.Tthe VTEC pressure switch isnt plugged in but it doesnt need to be if the ECU were programmed to not use it. Also, doesn't matter what ECu you have because they can all have VTEC added and chipped. Not saying yours is, but you will to open it and find out at least.
"Black people can't be racist" - Some black guy.
2001LXCivic
Jun 28, 2011 05:08 AM
chirby17
Oct 27, 2010 07:35 PM
MazdaMX3Freak
Sep 5, 2007 06:56 PM
edmel89
Jul 29, 2007 07:42 AM
vonrobins
Nissan/Infiniti Tech
15
Nov 24, 2006 06:15 AM
