HELP ME!!!!!
Old Jan 7, 2003 | 09:02 AM
FUNKYGSR's Avatar
Default HELP ME!!!!!
HOW MANY VALVES DO YOU NEED 4 OR 8 IF I AM SWAPPING THEM OUT FROM STOCK TO SKUNK2. WOULD STANDARD OR HIGH MAKE A DIFFERENCE. PLEASE HELP I AM RETARDED WHEN I COMES TO THIS
Old Jan 7, 2003 | 10:26 AM
Alpha's Avatar
What kind of car do you have? I know I would need 16 valves in my four banger This has been discussed before.
<Skunk2>
Skunk2 Racing valves are made from SAE EV8 stainless one-piece forgings, which are then heat-treated using a proprietary heat treatment process. After CNC-machining and swirl polishing, a PVD black nitride coating is applied to reduce friction and increase wear resistance. Skunk2 Racing valves are lightweight, durable, and offer excellent heat and corrosion resistance. Skunk2 Racing valves are available in standard and high compression styles and also in various sizes. Oversized valves should not be used with standard size valve seats or with Stage II and III VTEC camshafts.
</Skunk2>
Please post through again
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Jan 7, 2003 | 11:09 AM
FUNKYGSR's Avatar
I HAVE A 99 GSR.. SO WHAT IS THE SIZE OF MY VALVE SEATS?? WOULD IT BE BETTER TO GET THE HIGH COMPRESSION VALVES.. WOULD I HAVE TO CHANGE UP MY VALVE TRAIN?
Old Jan 7, 2003 | 12:48 PM
FUNKYGSR's Avatar
ok thanx.. should i go high or standard if i am going all motor
