Welded Mounts
Old Jan 2, 2003 | 02:08 PM
CiViC 311's Avatar
Default Welded Mounts
I dont know anything about mounts or what welded mounts exsactly mean. I have a bmotor installed into a 88 hatchback. I was told that they were welded. Can someone tell me if welded mounts can be reused?
---Project 88-----
"wuuuu,look at me I drive a V8"
Old Jan 2, 2003 | 02:56 PM
cykociv's Avatar
Up and running
Why are do you have welded mounts with a B-series motor?
" Nitrous is like a hot chick with an STD, you wanna hit it, but you know what the consequences might be "
Old Jan 3, 2003 | 05:21 AM
CiViC 311's Avatar
Well I should just get a new mount kit. Are there any other companies that sell them for less the $480. That would be with shipping Iam est. it at. Hasoport sells them for like $450.
---Project 88-----
Old Jan 6, 2003 | 12:43 PM
KJ's Avatar
KJ
bored at work
On a crx with a b-series swap the upper tranny bracket is chisseled away and rewelded in a different position. The stock 90-93 teg mounts are used. If you switch to a mount kit you will need to chissel that bracket off again and reweld it in the stock position for the mount kit to work. A mount kit is definitely the way to go but in your case you have to make sure during the last weld in job the chassis isn't too messed up from the chisseling. I think you could buy another spot weld bracket from Honda but I'm not sure. You might be best off keeping the weld-in setup since it is already done. And yes the mounts can be reused if they are in good shape.
Old Jan 6, 2003 | 01:37 PM
CiViC 311's Avatar
ok man thanks kj. I just better go ahead and get a haspot kit. Nothing seemed to be moved around. I think It can be reused but everyone that knows what there talking about says just get a kit. Thats what iam going to do. In time I'll have one.
---Project 88-----
