need help with gauge cluster rpm problem
Old Jun 19, 2012 | 06:07 PM
allmotordaniel's Avatar
Default need help with gauge cluster rpm problem
is my second cluster i put in it n it does the same thing.. i have a itr motor on my 95 civic n the rpm never reads right n now it only max out at 7 ..advise if you ever ran across this prblem n what you think about a digital rpm reader???? thank you
Old Jun 26, 2012 | 01:31 AM
racin's Avatar
ZMR
what ecu are you using
ZMRacin...for the people since 1998.
typeZ zionmotoracin@gmail.com
> #zionmoto #s1built #battlegroup3<
drag honda / drift soarer / road race benz
Old Jun 30, 2012 | 05:10 PM
a chip p28
Old Jul 1, 2012 | 07:39 AM
BoostedRacerDad's Avatar
Pops
If you already have a aftermarket fuel pump, which you should, problem is most likely the ignitor in dizzy.
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Jul 1, 2012 | 10:16 AM
fuel pump walbro ..n the dizzy is new ..it was find at first ..is find if you cruise but ones you hit it n it passed 7 it dossent read right
Old Jul 2, 2012 | 04:52 AM
Pops
As mentioned, the problem is most likely in the distributor, specifically the RPM output from the ICM, [ignition control module or igniter] it is the blue lead at the distributor assembly.
The first thing I would check is the connection of the blue lead to the ICMs RPM output terminal.
This is the ICM...
There are only three components to your Tach.
1. Ignitor
2. Wire
3. Gauge Cluster (which has already been changed)
I have a box of aftermarket dizzy's all bought brand new from Ebay...everyone has a problem, just outside the warranty. "Ye olde box of Honda dizzy's"
JoKie TuNinG
StricKlyMT
727-510-6301
Old Jul 2, 2012 | 05:39 PM
alright im goin to try that out....thanks
Old Jul 2, 2012 | 05:43 PM
oh n i dont know if it makes a diff ...but the cluster i put is a jdm cluster but the mph been converted
marble hatch
Nissan/Infiniti Tech
6
Oct 26, 2009 08:41 AM
roachhatch
Mar 25, 2009 06:13 AM
Big Chris
May 17, 2006 07:10 PM
Stephan
Sep 25, 2004 10:06 AM
