fuel pump problems?? power to relay but pump wont prime.
Old Jun 10, 2012 | 12:56 PM
2qk4u's Avatar
Default fuel pump problems?? power to relay but pump wont prime.
i checked the relay and the harness and everything checks out fine and when i put a jumper wire on the relay harness the pump will turn on. wtf is going on
Old Jun 12, 2012 | 12:10 AM
If the pump is below the gas level it should be priming. Does it spit fuel out when you disconnect the hose closest to the pump?-Bob
Alex H.
Mar 23, 2012 05:57 PM
AustinSi
Jan 21, 2011 08:41 AM
insanecivic94ex
Oct 28, 2005 01:38 PM
