Head tapping!!
Old Dec 30, 2002 | 03:18 PM
2qk4u's Avatar
i know but a high comp piston has a dome, hence its closer to the valves.
Old Dec 30, 2002 | 03:19 PM
2qk4u's Avatar
sounds like you shit is totally fucked.
u have issues all the time
good luck
Old Dec 31, 2002 | 02:33 PM
RONIN's Avatar
Tetris on a stick
Default Re: Head tapping!!
its a honda, its supposed to tick.
esp when you start using bigger cams.
on my ls with 403s and springs/retainers, i think we went to 12lbs on the caps.
your head is not milled, and you have the correct pistons rods and crank right?
if you are actually tapping, re check to make sure your cam gear is set to 0.
we took my 403's 6 degrees either way wihout trbl, what grind are you running?
Eat a live toad every morning, and that will be the worst thing to happen every day.
Old Jan 1, 2003 | 04:41 PM
Bill's Avatar
Livin' in Seattle
You always seem to be having problems so I'd suggest you have someone who is experienced set the lash before going any further. You can check the lash and double check it all you want but if you're fucking it up both times...
Old Jan 4, 2003 | 11:44 AM
  #19 (permalink)
chi town brat's Avatar
! Ne shab'rud'ni !
Default hi
still heading out tonight? call me 813 787 7838
larterz
Old Jan 4, 2003 | 12:23 PM
  #20 (permalink)
Bill's Avatar
Livin' in Seattle
Originally posted by "CronicBurn"
Fixed. I went clockwise instead of counterclockwise.
