NEED HELP!!!!! car wont go into gear.
Old Mar 5, 2012 | 12:06 PM
delsol72's Avatar
Default NEED HELP!!!!! car wont go into gear.
Okay so i have a 1998 ek hatch Cx. I woke up this morning to leave for work and my car was in first gear and wouldn't start. So i put it in neutral and it started right up. Then I went to put it into gear and my clutch pedal went straight to the floor and I couldn't get it to go into gear. I'm not sure if its possibly the transmission or if I need a new clutch or maybe even the clutch slave cylinder. Any help would be very much appreciated. Lmk what you guys think or if anyone knows what it might be.
Old Mar 5, 2012 | 09:37 PM
Sno Wyte's Avatar
Kenpo Master Technician
did you check your fluids, check your clutch reservoir.
Originally Posted by BoostedRacerDad
When my vtec kicks, time and space collide....yo
Originally Posted by jst4shw
real rota wheels
Old Mar 6, 2012 | 08:07 AM
b18turbo's Avatar
either your master clutch cylinder or slave cylinder.. empty it out bleed the system till u get pressure that should do it...
Old Mar 6, 2012 | 10:08 AM
delsol72's Avatar
^^ that's what i ended up doing was just bleeding the system and refilling everything and its good now. Thanks guys.
Old Mar 20, 2012 | 11:17 PM
Thanks for posting up the results.
It makes a person feel good to know they got it right.-Bob
cheeseburger407
Projects and Builds
Jul 2, 2011 05:54 PM
ant87
Jul 12, 2007 01:59 PM
ccadman
Nissan/Infiniti Tech
17
Oct 19, 2005 02:54 AM
