Need info about replacing timing belt and H20 pump
Old Dec 11, 2002 | 08:40 PM
TypicalHYBRIDcivic's Avatar
Default Need info about replacing timing belt and H20 pump
My wife has a 96 Civic EX and has about 106,000 miles on it. I think it is about time to replace the timing belt, while I am at it might as well replace the water pump.
My ??? is, I have never done this. How massive of an undertaking is it?
I cannot see paying $300+ in labor for $60-75 in parts.
I am reasonably mechanically inclined, is it possible/worth doing it myself.
Any feedback would be greatly appreciated.
Old Dec 11, 2002 | 08:43 PM
team-hyper's Avatar
i want the pink stuff
Default belt
timing belts and labor aren't much, go to national auto and tire service center it should be around 50.00 for labor w/belt.the w pump, i have no clue,isn't that like inside the engine were you have to take apart half the engine just to get to it?
Old Dec 11, 2002 | 09:56 PM
StreetDriven's Avatar
I <3 your mom
Just half, the side where the cam gears are. I did mine it took a few hours going slow. its not hard so i would say do it yourself.
Old Dec 12, 2002 | 06:38 AM
BIG_Truck_Driver's Avatar
Wherever I may roam...
biggest pita is getting the crank pully off, you will need a strong impact gun or the special tool to get it off. other than that making sure the timing belt goes back on lined up and with the correct tension is the only thing to worry about.
