LS/VTEC????
thinking about building an ls/vtec for a 2nd gen teg...but i've been hearing alot of talk about unreliability for everyday driving just wondering what you guys think and if should i do it...thanx for your input
Guest
Posts: n/a
Well... I would suggest getting pistons and rods at the least if your gonna build this motor. Ive not built one, but hear many good things about them if built _correctly_.
Talk to John, Taylor, TK, or KJ about them.
If Im not mistaken, KJ had an LS/VTEC for 3 years and never had a problem with it.
Anyone else want to comment?
Originally posted by "2qk4u"
get ARP rod bolts, new pistons
new rings and new bearings, pumps ect. and it will be just fine
half ass it and pay the price.
anyway Ls\Vtec can be reible like he said build it right you get what you pay for !!!!!!!
97 ITR-Mugen Equiped
04 Honda 600RR
04 Honda 600RR
this build can get very pricey to build it reliably.
why not just get a B18C?
1997 Prelude, H23A1 VTEC
Items for sale:
H22/23 block and all internal parts
4 5th gen Prelude wheels, 16x6.5, 5x114.3mm bolt pattern
More stuff for sale:
https://www.tamparacing.com/forums/showthread.php?s=&postid=472993#post472993
Items for sale:
if your looking to build a powerful ls/vtec motor i would recommend ditching the ls rods and getting yourself a set of eagle h-beams with arp rod bolts. the poor rod to stroke ratio puts a lot of strain on the already weak ls rods and cylinder walls. also the pistons in an ls block suck for all motor, theyre very low compression. try some itr's or aftermarket ones. and lastly make sure you dont rev the piss out of it. the ls bottom end was only meant to rev a shade over 7grand max(unless u get a girdle). also use a stock ls headgasket, i tried one of those cometic "lsvtec" head gaskets and blew it in like 3 weeks. make sure everything is measured and installed correctly and it will last you a very long time.
