b16a on b20b bottom end...Help
Old Oct 5, 2011 | 09:34 AM
Hkposer's Avatar
Default b16a on b20b bottom end...Help
I'm sure someone on TR has done this swap before, any input is helpful considering I have read
50 different things about it.
Just wanna clear it up...I can use:
B16a
water pump
oil pump
flywheel and clutch
starter
alternator
b16 bottom pulley--->On my b20b bottom end.
Really i need to know what timing belt to use i figure b16a, but wanna triple check.
Old Oct 5, 2011 | 10:17 AM
Paulino's Avatar
Not harsh, just truthful
Timing belt goes as according to the head and water pump so yes you will be using a B16A timing belt.
Old Oct 5, 2011 | 10:30 AM
Hkposer's Avatar
sweet thanks one more question.
What head studs....b20, GSR, B16 ones are too short for b20b bottom end with b16 head correct ?
I have some b20 ones on hold but wanna make sure.
Old Oct 5, 2011 | 11:57 AM
Hkposer's Avatar
I need to know before 5 o clock..please
Old Oct 5, 2011 | 12:20 PM
Hkposer's Avatar
Most of my research is telling me GSR head struts. Hope its right.
Old Oct 5, 2011 | 12:53 PM
Paulino's Avatar
They are all the same part number from ARP (who you should be oredering from if not already) but B16 ones!
Old Oct 5, 2011 | 12:56 PM
Hkposer's Avatar
I was told the b16 ones are too short ? Its a b20b block
Old Oct 5, 2011 | 06:26 PM
LShatch98's Avatar
i love making you mad <3
they make arp studs for b20w/b16 head.
Proven Power for all your go fast needs
Old Oct 6, 2011 | 04:32 AM
Paulino's Avatar
^ What I was trying to say.
Old Oct 6, 2011 | 05:48 AM
BoostedRacerDad's Avatar
Pops
ARP Head Stud Kit: No Limit Motorsport
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
