cv joints keep getting destroyed 1992 ls....????
i have a 1992 ls integra and i destroyed a cv joint. i mean literally destroyyed it to where the piece that was stickin out of the half shaft was hollow. the three knuckle things were just hangin out... i went to autozone bought a brandnew one installed it and then took it for a test drive. shifted to second and hit 3000 rpm and it did the same thing destroyed it again like an internal bomb went off in it...
can some one help steer me in the r ight direvction cuz i have absolutely no idea what the hell could be wrong with it ive never seen this before
lmk thanks
lmk thanks
how low are you? extreme axle angles can cause this.
Proven Power for all your go fast needs
my guess is your differential shit out on you my friend, install a new cv and push the car and see if it starts to bind up. i went through like 3 cvs before i realized the differential took a shit.
i had the tranny guy come see the car and he said noth8ing was wrong with my tranny he said its from something being out of alignment the wheels or engine... the wheels were just aligned so how the hell could i fix an engine aslignment problem??? has anyhbody seen this type of problem before?
is it the passenger side ??? i told you i had the same problem and tranny was blown if you put the cv in and then just push the car to see if it starts to bind up if it does your tranny is probably shit
Yea take it to a new guy, that guy sounds like a idiot... And what side is ripping?
