intermittent starting problem
Old Aug 12, 2011 | 12:50 PM
redcoats1976's Avatar
Default intermittent starting problem
i have a 93 del sol,d16z6 auto.it runs great,most of the time but every so often it cranks but wont start.battery is good,plugs and wires are new,rotor and cap 6 months old.it has done this for a few years and usually once you crank it 4 or 5 times it starts and runs like everything is fine.this morning i thought i was going to be late for work,cranked it about 20 times and nothing,like its not getting gas,on the last try it fired right up and ran fine.what to check???
Old Aug 12, 2011 | 07:57 PM
yoshi06's Avatar
main relay.
Old Aug 12, 2011 | 08:03 PM
BoostedRacerDad's Avatar
Pops
Replace or repair main relay. Clean thermostat ground if that doesn't do it, I bet the ignitor in distributor is going.
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Aug 13, 2011 | 05:34 AM
thanks for the help.i cleaned the thermostat ground this morning.hoping that will help but if not i guess the main relay will be up next.glad you sent the picture...
JDM S14
Nissan/Infiniti Tech
Aug 19, 2010 02:03 PM
slowrex88
Jul 30, 2010 07:15 AM
redcoats1976
Jul 14, 2009 02:28 PM
Bftsupra
May 18, 2009 07:37 AM
