Crower Issues
Originally posted by "CronicBurn"
If this is the case, and I join the others with broken shit. I will file a suit against them, your all welcome to join in.
Cali
Hopefully I will not share the same fate as you guys.... Your stories worry me though. If they break, and I have to deal with the same shit you guys did. I'll not only be taking a trip to thier main office to speak with Brian and David... I will also deal with thier servers in a most apropriate way.
Guest
Posts: n/a
My 1400 spent included the head job, valve seat oversizing(.5mm), port and pollish, and install of the cams and everything else, also the Ti retainers, springs, and .5mm oversized valves. Basicly the car has a fully made head. I don't believe there is anything else that can be done to it.
Back cutting valves is one of the best performance mods for a head.
You can also do a 3 angle cut to the valve once this is done.
What they do is remove all the metal from the back side of the valve and thus allows more flow when the valve is opening and opened fully.
It also removes weight from the valve train with allows for faster revs and less friction. It also helps in keeping heat down in the head and intake/exhaust tracts
Do you have any idea how much CFM your are flowing now with 5mm oversized and the cams?
custom parts is our perfection.
5 and 4 angle cuts are more for Amercian V-8 engines.
The reason it is not best for imports is imports have less metal on the valves to remove, so they can't do 4 or 5 angled cuts.
3 angle cuts is the best for your application.
If I was you, I would find out what CFM your are flowing in and out with all these mods you have. Bigger is not always the best power producer.
You really want to concentrate on velocity, not just sheer flow. Higher velocity will produce more power, better mileage and better response.
What is the CFM of the turbo? both sides?
I would start to see what you are flowing, this may help correct any problems you have later.
It would suck to have one cylinder run lean, like number 4 as it see the coolant last and get the hottest air from the manifold.
Also with these mods and not know the flow of intake or exhuast, you may get stacking in the intake being your turbocharged. Thats not good either.
Lets learn what you are flowing first!
