oil pressure H22?????
Old May 24, 2011 | 12:01 PM
OldSchool Mike's Avatar
Civic Duty member #001
Question oil pressure H22?????
What can cause low oil pressure? i need to know every possible reason to fix my problem.
thanx
Old May 24, 2011 | 02:02 PM
NeKe1point0's Avatar
bad oil pump, or leak ...
Proven Power LLC
4505 N. 56th street
Tampa, FL 33610
813-988-DYNO(3966)
www.ProvenPowerTampa.com
Old May 24, 2011 | 06:47 PM
tuboteg110984's Avatar
superbeast
rod bearings goin out
Vtec??????
LS turbo 400WHP
H22a hatch 5 lug 187WHP
Old May 26, 2011 | 03:32 PM
BlackZ28's Avatar
ppssshsshhhhhhh
is the motor doin anything weird or does it run fine? how did u check the oil pressure? we need more info...
www.mcgtile.com - Professional Marble and Tile Installation
Racing Integration
Proven Power
Old May 30, 2011 | 06:37 AM
it runs great starts right up and rides out but ive replaced the oil pressure switch on back of block as well as the one on my vtec and redid all my wiring and still vtec breaks up on me it gos in & out of vtec also just did an oil change. someone told me that taking your check engine light out of your cluster breaks a connection to your ECU and could be causing my issue with breaking up. True or false?
Old May 30, 2011 | 07:42 AM
Gotrice?'s Avatar
lol no. honestly i had this same problem bro and it turned out being my distributer. try finding somone with the same setup as you and swap him ignition control modules. if you dont know anyone then buy one and if it doesnt fix your problem take it back. its realy easy. i went for a year with my car running like this and could never figure it out untill i changed the icm!.. you should also try and fix whatever your check engine light is on for. check the codes
Midori Teg in the making..
Old May 30, 2011 | 04:09 PM
thats my point the bulb isnt even in there so i have to put it in and then check my codes. ill check my dizzy too thanx
Old Jun 1, 2011 | 10:20 PM
bettaberettaboy's Avatar
That Fat Guy
Dented oil pan, clogged or dented pickup tube. Sounds like your not cycling oil well enough at higher rpms, possible pump issue but check the pan and around the picup tube first. its actually a quite common cause
Old Jun 4, 2011 | 07:24 AM
Thats what it was cause now its workin perfect! my picup was flat on
my oil pan
Old Jun 4, 2011 | 06:18 PM
That Fat Guy
Yeah thats a common cause on Hondas cause everyone slams em LOL Glad I could help
hondajeff
For Sale/WTB Honda & Acura
5
May 12, 2011 08:17 PM
bigpudge
15
Dec 22, 2010 12:51 AM
boostedbeast
For Sale/WTB GM - Buick, Cadillac, Chevrolet, Pontiac, Saturn
Jan 31, 2008 05:19 AM
864I'DCaprI
Nov 17, 2007 05:46 AM
jota69
Jan 27, 2007 05:41 PM
