Need Starter Help!!! aidufhawuefyhauf
Old Apr 6, 2011 | 05:21 PM
babyhatch94's Avatar
Default Need Starter Help!!! aidufhawuefyhauf
So i got a 90 DA integra, with a bseries and when i turn the keep to start the car, the radio and all lights turn on until i go to that final click to turn over the motor. That is when all i hear is a metallic click and everything dies again...when i tried connecting the power to the starter from the motor itself, it doesnt even turn over...so i replaced the starter, worked for 2 weeks and then its doing the same problem AGAIN!!!
what is it? the battery? voltage? bad luck with starters? a relay?!?!
SOMEONE HELP ME!!!
Old Apr 6, 2011 | 05:37 PM
sburtoncivic98's Avatar
Most likely the battery, check the water level, if low fill with distilled water and put on a charge, if the car dosent start after a good charge, or a quick jump pack then your starter might be wired wrong. I know it sounds weird, but if wired wrong it can start and run but will drain the battery. Also if it does start put a multi meter on the post of the battery and see if the voltage is around 13.50 to 14.00, if you get that voltage output you have an good alternator.Also might be main relay. I need to puts my thinkin cap on
TR "Old Skool EF" Member #210
insanecivic94ex
For Sale/WTB Honda & Acura
Feb 10, 2011 04:56 PM
94lsteg
Oct 21, 2009 11:48 AM
japanbran
Aug 25, 2007 06:51 PM
eksilver1
Nov 3, 2005 03:36 PM
Old Renegade
Aug 12, 2005 04:38 AM
