Fluctuating tach and random stalling DC2 Teg
Old Apr 6, 2011 | 03:42 AM
That One Guy's Avatar
01' Integra.. Slowness
Default Fluctuating tach and random stalling DC2 Teg
Hey TR, I just picked up a 01 Integra LS a few days ago from a friend. Anyways he told me that when it is cold outside the car may randomly stall. Well this morning it was a bit chilly and it stalled. It happened after about 5 mins of driving and the car was fully warmed up, the tach started swinging widely (independent of the actual rpm of the motor) I slowed down and pulled off the road as soon as I stopped and pushed the clutch in to pull it out of gear the car stalled. After a min or two I started it back up and had no other problems all the way to work.
I’m thinking it is the igniter (ICM) or maybe a loose ground or possibly even some loose wires on the ICM itself.
Basically throw me some ideas so I can trouble shoot.
Also when it is warm outside the car runs just fine no problems at all.
Old Apr 6, 2011 | 05:50 AM
BoostedRacerDad's Avatar
Pops
Do these tests
Advanced Ignition Troubleshooting - Team Integra Forums - Team Integra
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Apr 6, 2011 | 07:51 AM
Thanks this gives me a reason to get a multi-meter
Any other ideas why this may only happen when it's cold outside?
Old Apr 6, 2011 | 09:35 AM
Pops
You might have a crack in the dizzy cap or you are missing the "O" ring on it and when it is cold you are getting dew on the coil or ignitor causing a arc.
JoKie TuNinG
StricKlyMT
727-510-6301
Na306StAnG
Dec 23, 2010 04:39 PM
Bob13bt
Jan 5, 2003 07:40 PM
advan7
Feb 18, 2002 08:58 PM
