help with overheating problem
Old Feb 27, 2011 | 06:56 AM
X_clusive1's Avatar
Default help with overheating problem
ok i got a 99 civic d serie motor , this started on thursday . i had the car running with the ac on , next thing i know i see smoke coming from under the hood , i look a the temp gauge and it dosnt show that its overheating . ii turn off the car and pop the hood. i see coolant all over the tranny and some on the hoses and alil on the fan . then i check the rad to see if there any coolant and there none . i put coolant in turn on car and everything fine .i drove home with no problem no smoke no overheating . next day im driving home from work and i come to a red light and see smoke coming from under the hood again and the temp gauge showing that its overheating this time . so i pull over pop the hood same thing all over again. this time i notice that the upper hose is geting hot like normal but the lower hose , so i figure the thermostat is stuck and making the car over heat . so i change it yesterday turn on car let it run with ac for a while everything good no over heating , i start to drive to the beach nxt thing i know smoke again , coolant over the tranny . i dont know what it could be , i can find any leaks , can some one pls help with some info or if some could come check it out , ill give u a brand new rear bumpe for ek coupe and burn L if u burn
Money Make Me Feel Better
Old Feb 27, 2011 | 06:58 AM
X_clusive1's Avatar
i have a new rad coming in next week and i got a new water pump , but i dont thik its the pump because it on the timing side of the motor
Old Feb 27, 2011 | 07:06 AM
b18turbo's Avatar
Since u replaced the thermostat and u purchased a water pump, radiator might as well buy new hoses
Old Feb 27, 2011 | 07:07 AM
b18turbo's Avatar
Check your intAke manifold gasket
Old Feb 27, 2011 | 07:09 AM
X_clusive1's Avatar
yea im ganna buy new hoses when i get the new rad in the mail
JDM-EK20Ferio
Jun 14, 2010 04:33 PM
b15spec
May 17, 2010 05:33 PM
Davetheslave
Nissan/Infiniti Tech
19
Sep 8, 2009 11:01 AM
