Bucking and hesitation...
Old Oct 1, 2002 | 07:19 AM
ghuey's Avatar
member
You still need to trim out some fuel under vacuum,the vafc, 8 to 1 disc and some tunning from john should solve your problems...One other thing are you using check valves on the map sensor or a missing link..If you are not using the missing link I would get one.....
~Guy
Old Oct 1, 2002 | 07:50 AM
98VR6's Avatar
Default YOUR PROBLEM
YOUR BIGEST PROBLEM IS YOUR TIMING YOU NEVER ADVANCE A BOOST CAR YOUR LUCKY THE MOTOR HASN'T BLOWN UP. AND CHECK YOUR MAP SENSOR ITS NOT WORKING RIGHT. THE FACTORY MAP WILL NOT READ BOOST YOU HAVE TO REMEMBER THAT THAT CAR WAS NOT MADE WITH A TURBO.!!!!!!!!!
IF YOU CAN'T RACE IT OR TAKE IT TO BED IT'S NOT WORTH HAVING!!!!!!!!!!!!
Old Oct 1, 2002 | 10:14 AM
99B16Si's Avatar
timing can cause more problems then youre seeming to think. cam and ignition that is. u also need something for your map sensor. youre right, it will read 13lbs of boost but not on the stock computer. your stock computer will pick it up pretty quick when u hit boost and compensate in its own way which will not feel very good. u need someone who knows what hes doing to look at that thing before your laziness blows up your car. oh and how many lbs of boost are u running. your timing is about 8 degrees off from where it should be. too much boost + too much timing = BOOM!
Old Oct 1, 2002 | 10:50 AM
  #18 (permalink)
ghuey's Avatar
member
If your map sensor is reading boost ie no check vavles or missing link that would explain a big part of your problem.Even though the map is capable of reading boost up to 11 or so psi, the factory computer was never designed too.As soon as the computer reads boost it goes into limp mode.It will reduce the rev limit to about 4000 rpm...Unless you have hondata or some other standalone you must use something to stop the map sensor from seeing boost...
~Guy
Edit sp
