integra 4wheel disc on my 93 CX(questions)
Can i use the Stock civic Steering knuckle ? Can i use my civic brake lines? If u have n e info u think i should know please post. Thanks for ur help.
everything will hook up. Just get a 94 up integra rear suspension make sure it comes with the calipers,rotors,brake hose and ebrake. The ebrake cable on the civic is to short and wont work. You have to get a integra ebrake cable which fits perfect. Bolt on the rear trailing arm and hook up the ebrake cable and your good takes about 4 hours max to do the swap. Its really easy. You dont need any type of manual or anything its all basic knowlegde on brake. If you know how to bleed your brakes right then your set. You dont need to upgrade to the 1" m/c or p.vavle its not really that necssecery at all. There really isnt that much of a differecne at all.
If you got to getting bigger brake setup then it might be in the future. A noticeable change in stopping power is notice. I had to give mine time to set in for it to feel right.
