Rod encaps... a blunder...
Old Sep 17, 2002 | 09:26 AM
KJ's Avatar
KJ
bored at work
note: my experience in building motors is with b-series
It's not too bad. The rod should have a number stamped on it. Half of the number on the rod itself and the other on the end cap. Just put the two together till they match. Now this number does not correspond to the cylinder it was in, it is for bearing sizes so there might be 2 rods stamped with the number 2 lets say. Since the rods are used and they might have stretched alittle they shouldn't be mix matched even though they are stamped the same number. Have the rods resized by a machine shop, cost is like $10 a rod. This assures the big end is true round. Do this and plastigauge clearances when you reassemble and you will be fine.
Kevin
Old Sep 17, 2002 | 03:14 PM
Bill's Avatar
Livin' in Seattle
You keep track of them for bearing clearance reasons. I wouldn't worry too much about matching 'em (aside from number halves) since it would appear that you're changing out the bearings anyways.
