Ls/vtak build
Old Dec 17, 2010 | 08:20 AM
89crxsir's Avatar
stock cams for now. it will be kinda a dd for the time being.. i put 2k miles on the car this year.. i'm gonna try and get factory bearings, or if there are other bearings that will be better. stock injectors, e-bay header for now. i got full exhaust and a 12lbs flywheel and a 6 puck clutch.. I'll take all of the info i can get!!
SEE NO EVO HEAR NO EVO!
If i put half a tank of Shell V power, and half a tank of Chevron with Techron. Will i get v-tec??
Old Dec 17, 2010 | 12:29 PM
sxysweed's Avatar
CRX.XXX
I don't know about b-series, but stock cams and 12:1 compression is kinda finicky. Might be hard to get it to run well without knocking and still make decent power. Don't see why you couldn't run 12.5:1 compression with some wilder cams though.
Old Dec 17, 2010 | 12:46 PM
SloCivic's Avatar
Originally Posted by sxysweed
Take it slow and easy, don't rush things. If your tired, take a break and resume another day. Remember, if a girl (Chi Town Brat) could manage to assemble a engine (an engine! not a sandwhich) you can too.
Old Dec 17, 2010 | 01:36 PM
JoKiE crx4294's Avatar
popeye built!
buy a k instead.
Can't spell strength without tren
AAS...It's whats for dinner
Old Dec 17, 2010 | 01:53 PM
89crxsir's Avatar
i'm looking at spending 2k not 6k.. I got 1/2 of the stuff for the conversion already
Old Dec 17, 2010 | 02:23 PM
rangcrx's Avatar
engine building &best
2k will get you a good start.I would really look into cams and I would not go that high compression u will still make the same power with wiseco low domed pistons
i love AUTOZONE
Old Dec 17, 2010 | 08:17 PM
  #17 (permalink)
Paulino's Avatar
Not harsh, just truthful
^ This. A head package is necessary with that compression. And why not just save up some money and get some quality parts for some good power. I'm sure you'll be disappointed with the results you'll get in not be patient with the build. I mean if you plan on it just being a quick daily then why not? Itr cams aren't too expensive around $250-$300 used off of here and you'll be happy for your goals i guess. It's kind of odd that you have 12:5:1 wiseco's in the block but then and ebay header and stock cams. Fuel is another issue that you really need to adress. Look up some ls vtec builds on honda-tech.com. Do it right the first time around.
Old Dec 17, 2010 | 09:25 PM
  #18 (permalink)
92 CiviC H/B's Avatar
-Proud Croatian-
do it right and be patient,we wouldn't like to see you posting a thread saying ls/vtec failed. patients is key,be organized and clean and make sure you go over everything at least 4 times. have all the torque specs and sequences on hand. good luck.
.TR's OldSkool DA Crew Member #14.
Old Dec 18, 2010 | 06:49 AM
  #19 (permalink)
chi town brat's Avatar
! Ne shab'rud'ni !
Originally Posted by 89crxsir
Thanks for all of the info!! I'm sure i'll be asking a lot of questions in the next few weeks.. I figure i'll find a good block and crank, build the motor on a stand then drop it in in a weekend.
When you look for a block check to make sure the caps don't move and they don't have a copperish color to them. This is a sure sign there has been damage done to the block and it will not be rebuildable.
btw thanks guys, if it wasn't for David Green and others I wouldn't know ish!
Old Dec 19, 2010 | 01:34 PM
  #20 (permalink)
eightwun3zfynest's Avatar
sleeper
i got some RC Racing 370cc injectors for 250 itll be nice for your build! but like every1 is saying just take your time and MAKE SURE to get good quality parts!
