DX to Si swap.. Wont Stop?
The mother fucker starts now but now it wont shut off.... I take the keys out and the bitch is still going???? This is some wierd shit... Any Ideas?
drive that fucker like you stole it
im the one who wired it and believe me i made a checklist of every last thing that could have gone wrong wiring and the 2 white wires was the 1st thing to come to mind but that doesnt explain why no power is gettin to the ecu does it...it doesnt flash when u turn the ignition and im sure i did the pinning right..i followed the instructions to a T and went over it again. He was thinking of hardwiring the power wire from the ecu to the ignition and see if it is that... i guess eddie had lost the ecu wire from the SI harness, it was weird how he had it, it was like a 8 guage cable running from the fuse box straight to the 12v on the battery (should it have been that way)
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
i dont recall my ecu blinking unless it was throwing a code
is it supposed to blink when u turn the car on?
and u said SI HARNESSS?????
u need a DX harness
and if u already had a si then dont it have the res box already??
u need a DX harness
yea...its not even flashing and it was working perfectly when we pulled it outta the Si...as for the wiring, yea...but he was thinking wire it under the dash to the ignition or something... i told him to see if its gettin fuel so he gunna spray some carb cleaner into the intake and see if she is gettin gas...then i guess next would be check to see for spark...still trying to figure out whuts up with the ecu tho
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Hum.... I have no clue of the ignitor having anything to do with the swap, all you should had of done was cut a few wires and splice them to the wires you added to the ecu. Where di you get the directions to do the wiring?
