DX to Si swap.. Wont Stop?
Old Aug 19, 2002 | 08:07 PM
Fastwitdawomen's Avatar
I tried both the Si and DX ecu and got nothing. The copper crush gasket on the fuel line going into the fuel filter is bad and it was shooting out gas, so I know its getting gas. I got the bolt as tight as I could and tried again and still nothing. I will try the reversing the 2 white wires and see if thats it. Its also getting a buzzing sound out of the dash on the left side of the stering wheel. It almost sounds like a fuel pump type of buzz. Thanx
Eddie
drive that fucker like you stole it
Old Aug 19, 2002 | 08:10 PM
foesicks's Avatar
what kinda motor are you running? Make sure ALL your grounds are good, i never new what kinda problems a simple ground could cause until i swap in a z6.
Old Aug 19, 2002 | 08:17 PM
I just converted from the std to my Si crx motor. A little more power for now. But I was afraid of some shit like this happening. I have no luck...
Eddie
Old Aug 19, 2002 | 08:19 PM
2qk4u's Avatar
U ARE USING A DX HARNESS RIGHT??????
Old Aug 19, 2002 | 08:20 PM
2qk4u's Avatar
the inside wiring for ur car is still dx. si harness on the motor would not work i think
Old Aug 19, 2002 | 08:25 PM
foesicks's Avatar
whats all the talk about si wire harness? you should not have needed anything from an si harness, well injector clips maybe but that its. Are both cabin and eninge bay dx harnesses?
Old Aug 19, 2002 | 08:29 PM
  #17 (permalink)
I used the dx harness with Si injector clips..
Eddie
Old Aug 19, 2002 | 08:36 PM
  #18 (permalink)
foesicks's Avatar
Huummm... their should be no problem then. What article did you use to do the wiring? check this write up out, it is by far the best for this type of swap https://www.tamparacing.com/phpBB2/viewtopic.php?t=30325 its from over at honda-tech.
Old Aug 20, 2002 | 10:45 AM
  #19 (permalink)
Sneakin Deacon's Avatar
PSSHHH x2
we used the one article on hybrid, and yes its the DX harness, just got the si injectors and box thas it...
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Aug 20, 2002 | 02:16 PM
  #20 (permalink)
Kenny you are repeating me. I can handle this. Go away.. lol.
