LS/VTEC HELP
Old Aug 8, 2002 | 05:30 AM
Hyper2002's Avatar
well I have decided to resleeve the block but I am going to go with a standard boar cause I already have the 11:1 pistons
Old Aug 8, 2002 | 06:59 AM
hybridsi's Avatar
There would be no sense in resleeving the block if you are going to maintain standard bore. If you are going to have the block sleeved go ahead and have it resleeved to 84.5 and have a nasty 2L motor. You can sell the standard bore pistons at a slight loss and buy larger diameter pistons that will achieve your 11:1 compression ratio.
Trust me, in the end you will be mush happier!!!!
HTH
Zach
"Friends LET friends get MULLETS!"
Old Aug 8, 2002 | 08:37 AM
Hyper2002's Avatar
Which was my goal I am going to resleeve the block with some darton sleeves and spray the hell out of it 150 shot or more I am going to do head work as well.
Old Aug 8, 2002 | 09:44 AM
Hyper2002's Avatar
Thanks for the point will be sure to check it out
