Need help w/ ID on tranny
Old Aug 19, 2010 | 11:56 AM
Vonduck's Avatar
Bourbon Powered
Default Need help w/ ID on tranny
Ok TR, I need some help identifying this trans I just picked up. The barcode label is missing and all I have are the markings on the outside of the case.
Looks like YSK 1, and some B markings on the side of the case. Check the pics. Hopefully I can get the info so I can start gathering the rest of the pieces I need.
Thanks in advance for some knowledge.
Insert humorous quote here
Old Aug 20, 2010 | 11:35 PM
HondaHouse's Avatar
IS AT THE DEALERSHIP NOW
by the pics and angles, i cant even tell if its a cable or hydro trans.....you may end up having to crack the trans open and start counting teeth to be sure
Mike @ 239-851-3234...anything pertaining to HONDAS
Originally Posted by Jordan T
sounds like you have a problem, your car is a mitsubishi, try replacing it.
