Affordable Honda Standalone
Old Aug 17, 2010 | 09:57 PM
MightyMaxGS-T's Avatar
Default Affordable Honda Standalone
I've been doing some thinking lately and I have been considering building a megasquirt 2 based standalone system for the hondas that would plug right into the obd1 harness. no more searching for p28s, no more having to buy chip burners or chips to burn on. with the capabilities of just about any standalone like boost control, knock control, flat shifting, anti lag, etc. if there are people interested i will build it but i just would like to see where the interest level is currently. i would be aim to make the system cost somewhere between $300-400. there would be no wiring involved just plug and play. i know i haven't really given you any specifics yet but it's just a thought, let me know what you guys think.
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
Old Aug 18, 2010 | 05:35 AM
DC2_BoostKING's Avatar
CRAWFORD BUILT
AEM EMS Series 2. it's what i'll be running (hopefully soon) in my Integra. Affordable... it isn't.
i'd just go with NepTune RTP if you need bang for the buck.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Aug 18, 2010 | 06:48 AM
integra's Avatar
90% grind 10% sleep
Do it. Blake did it a long time ago,with Uberdata. He never charged for it,but it kinda lead the tuning software game in the right direction. Although he never patiented it,he made a great program at that time.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Aug 18, 2010 | 09:03 AM
I mean I see what u are saying but don't u think it would be a little easier tuning on the fly with a system like this where you don't have to burn chips or solder on ur ecu? Just plug in to ur harness and then plug into ur laptop and start tuning. Its just a thought but I want to get other peoples opinion.
Old Aug 18, 2010 | 09:24 AM
custom240sx's Avatar
DC Crew Member #1
If you think you can do it go for it...it would be interesting if you get everything working well. I've worked with megasquirt before.
Old Aug 18, 2010 | 09:42 AM
it's not so much and issue of if i can, its more like should i, you know? if i get a response i'll probably do a month or two of r&d before i release it.
Old Aug 18, 2010 | 12:11 PM
DC Crew Member #1
Well just to forewarn you...this IS tr, and tr doesn't like spending money sooooo...I don't know how well it will take off. If you do it, it may just benefit you and maybe a few others.
Old Aug 18, 2010 | 06:36 PM
yea i was thinking the same thing, i was just seeing what kind of reaction i'd get, not much obviously...
Old Aug 19, 2010 | 05:29 AM
CRAWFORD BUILT
my bad dude i read that the first time and thought you were looking for a standalone
i would be interested depending on how detailed this would be, i'm back and forth on wanting to get Neptune until i can save the $1300 for the AEM EMS 2 of to just wait and save out right for it (or use financial aid money ). i also know of several people up here that would be as well.
would this include software, base map features, auto correction, stuff like that?
CRAWFORD BUILT
DC Crew Member #23
Old Aug 19, 2010 | 07:40 PM
Alpha's Avatar
HRTuning - Home Of The NepTune RTP and TunerView
The NepTune RTP (Real-Time Programmable) System Sale for only $399
This package includes one Demon unit (Pictured above) and one software license for the NepTune RTP software backed by our 100% satisfaction guarantee. Read below for details on our satisfaction guarantee.
Enjoy access to these great features of the NepTune RTP software (Pictured Below):
Beautiful 3D Beveled interface.
User Friendly Toolbars with the options you need most.
Real-Time Datalogging Of Sensor Data, Inputs, Outputs, and ECU Data.
On Board Logging With Lossless Compression To Allow 3 To 5 Times The Regular Amount Of Data To Be Recorded. Offers Up To 12 Hours Of Datalogging Time With Compression Enabled.
Datalog Playback, Save, and Export to CSV.
Datalog Trimming.
Datalog Commenting For Later Review or Sharing With A Tuner.
Graphing Of Sensor Information With Real-Time Values and Live Scrub (Dragging with mouse).
Live Graphing Of Real-Time Sensor Trends.
Direct Serial Logging From LC-1, LM-1, and LM-2 Products (LM-2 currently requires connecting hardware to allow legacy serial connectivity).
Map Trace and Lambda Trace.
24x24 Ignition and Fuel Maps For Precise Tuning.
Dual Tables For Low/High Boost, Different Fuels, or Alpha-N (ITB) Tuning.
Easy Injector Sizing.
Fuel Trims for Cranking, TPS Tip-In, Post Start, and Individual Cylinders.
Rev Limiter with Fuel Cut, Ignition Cut, or Both.
Rev Limits Per Gear.
Launch Control (2-step) With Anti-Lag.
Full-Throttle Shift.
Use The Check Engine Light As A Shiftlight With Different RPM Settings Per Gear.
Idle Adjustments for Idle Speed, Idle Speed vs ECT, and Idle Ignition Corrections.
Air Temp Corrections.
Water Temp Corrections.
Gear Based Fuel and Ignition Corrections.
Access To Many Other Stock Fuel and Ignition Adjustments.
PWM Boost Control With Simple, Boost By Gear, and Gear vs RPM Modes.
Quad Stage Boost Control.
Adjustable Prime Duration At Key On.
Overheat Protection.
Closed Loop Control With Selectable O2 Input, Conditions, and Wideband Support.
Anti-Theft feature requires inputs or a code to be entered with TPS and Brake pedal. Also has a valet/fallback mode with adjustable rev limit.
2 Multi-purpose Outputs With Fuel and Ignition Adjustments.
1 Multi-purpose Output With Multiple Output Settings Based On MPH.
4 Programmable Analog Inputs For Extra Sensors.
And A Lot More!
Let's compare to the other three best known systems out there.
What makes NepTune a better option than Hondata S300? NepTune has more usable features and comparable features that exceed the configurability of a Hondata S300 (Like Anti-Theft, Up to 3 hours of on board logging with better start and stop parameters, access to more ignition corrections and the ability to disable corrections completely, direct serial port logging with Innovate Wideband products, and live graphing just to name a few) at a much lower price because we don't have as much overhead. We don't sacrifice quality because we have a lower price either... In fact everything is thoroughly tested and stable before being released to the public and updates to improve usability occur regularly. NepTune offers the best support in the industry, and we'll make sure you have the best experience possible with our system.
What makes NepTune a better option than Crome? The list of features NepTune has that Crome does not is endless, and at $44 more than a Crome Pro Tuning Package (Ostrich-$175, Hulog-$30, and Crome Pro-$150) it's worth it! Complete ignition control, better datalogging, datalog graphing, live graphing, PWM boost control, Anti-Theft, and a huge list of other features can really make the difference when it comes to tuning a vehicle. Best of all our features work properly so you won't struggle with tracking down bugs. Have Crome already? Find out about our trade-in offer.
What makes NepTune a better option than eCtune? While NepTune and eCtune have a very comparable price and feature list (They have a few we don't have... and we have a few they don't have yet, like Anti-Theft, on board logging, and proper closed loop wideband support), NepTune has been around longer and is more thoroughly tested before releases. Best of all it shows. NepTune's features are rock solid, our support is second to none, and our support forum is not constantly full of bug reports. We also don't force you to update your software if you're happy with the current version. Have eCtune already? Find out about our trade-in offer.
So why choose the NepTune RTP? Besides the reasons we've just mentioned, if you purchase directly from HRTuning and you're not 100% satisfied with the NepTune RTP within 20 days of delivery you can return your NepTune RTP System in perfect working condition for a full 100% refund on the cost of the NepTune RTP System. For trade-in packages you'll receive a refund and your trade-in items back.
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
