CTR JDM Pistions
Would this raise the compresion on a b16A w/ 10.4 comp. Or what would be good pistions to have in their? Were do I take my block to get it bored then honed? If i want the .25 oversized? I was wantting to get pistons put in since my motor is outta the car if that even matters. But wantted to do it anyways before I enjoy.
WTB:A clean 90-91 civic hatchback. Red or black or white in color. Good exterior. Looking to spend around $2,000.
not ctr the dome is to high i wouldnt do that youll have valve clearance issues.just put in integra r pistons an do a little mill job on trhe head
97 ITR-Mugen Equiped
04 Honda 600RR
04 Honda 600RR
ITR pistons will actually lower the compression in your B16A. the B16 pistons are domed more than ITR's. i believe CTR pistons in a b16 are 11:1 with a stock head. 11:1 for all motor sounds good to me
If i mill the head? Wont the comp. be to high for daily driving?
How much should I go to get them in safe without problems with the vavles?.How high of comp. can i go anyways with my b16? so that it can be dalily driven?
Guest
Posts: n/a
with ctr pistons your looking at around 10.8 in b16 i belive, from talking to skunk works, i have come to conclusion that the p30 pistons are best bet for b16!! just need to mill head some to get desired compression!! good luck! eric
