Car idles too high? b16
Old Aug 6, 2010 | 12:35 PM
Gotrice?'s Avatar
Default Car idles too high? b16
the screw in my throttle body is all the way in and it still idles at 1.5
anyone know what could be the problem?
Midori Teg in the making..
Old Aug 6, 2010 | 01:25 PM
Gotrice?'s Avatar
Old Aug 7, 2010 | 08:24 AM
Gotrice?'s Avatar
ttmft
Old Aug 7, 2010 | 08:44 AM
HaViKTypeR's Avatar
On The Paper Chase
Make sure you have no vacuum leaks, and check TPS sensor.
"Proven Power. Nuff Said"
"God is Good"
Old Aug 9, 2010 | 12:31 PM
sean83's Avatar
did it start randomly? or did u just swap it? maybe the tach is off... maybe you need to adjust the throttle cable.. more likely the answer above..
Old Aug 9, 2010 | 06:13 PM
flatrex's Avatar
crx hatch sedan
Fast idle thermo valve or fitv is your problem I bet. It needs to be taken off cleaned, inspected, then readjusted. I had the same problem with my b16 I did this and now my idle is at 700-800.
It's easy to do but if you need help shared_pm me
Old Aug 9, 2010 | 06:43 PM
integra's Avatar
90% grind 10% sleep
the screw on the top of the throttle body is not the idle adjustment.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Aug 11, 2010 | 09:45 AM
96spydergst's Avatar
Plug Off All Vacuum Lines That Are Not Needed. Use A Pice Of Wire On The Plug By The Ecu That Lets You See The Codes The Motor Is Throwing. Then Adjust The Screw On The Throttle Body. If It Still Idles High You May Want To See What Rshared_pm You Ecu Is Chipped For, Or The Iacv Or Fiv Or Tps... Maybe Im Wrong And Im A Butterfly Jumping On A Keyboard. But Who Knows?@?@?!!?!?@?@?@
I believe in a lively disrespect for most forms of authority.
96 eclipse gst drop top sold
98 civic EX sold
94 civic EX sold
94 cx H22A1 whippin
