Rebuild Question
Old Jul 15, 2010 | 06:52 PM
DC2_BoostKING's Avatar
CRAWFORD BUILT
OEM's are not file fit. plus they don't hold up as well as some of the other rings i've used. personally i like CP or Mahle rings. i have never used OEM Teikoku rings so i can't tell you about them.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Jul 16, 2010 | 05:36 AM
rangcrx's Avatar
engine building &best
YES KING BEARINGS ARE SHIT,they are the worst bearing i have seen for a honda byFar..use acl or clevite as long as you polishe the crank and your machine shop give you spec with in. 45mm +or- .1 your good
i love AUTOZONE
Old Jul 16, 2010 | 05:40 PM
civicized's Avatar
I like Mahle rings too, but I've also bought oversized OEM piston and ring sets and never had a problem with the gap being out of spec. I believe Teikoku makes most of the OEM rings for Honda, at least pre K series.
At any rate, one might make an argument for which rings last longer, but I don't think Honda would sell rings that are the wrong size (gap).
Again, ACL seem fine, but if your particular block/crank calls for off-size bearings, you can't beat the fitment of Honda colored bearings. They also help when building with forged rods, samples of Scat and Eagle I've found that spec out to needed red rod bearings in some cases. Run ACL in a case like that and you're too tight.
