need help with my 1991 dx hatch asap! please!!
defective circuit or unplugged / defective sensor
I would start there.
DAMN DUD I FEEL FOR U WELLL I HAVE A DX ALSO SWAP AND DUDE YES CHECK ALL GROUNDS TRANNY GROUND RADIATOR ETC................NEXT CHANGE THE MAIN RELAY.............NEXT IF U HAVE TIME N A COULPLE BUCKS CHANGE INTAKE MANIFOLD GASKET AND MAKE SURE ALL VACUUM HOSES ARE ON THE CORRECT SPOT CAUSE IF NOT AHH MAN UR TIME IS IN THE GARBAGE...................NEXT REPLACE UR ECU GO pr4 OR SOMETHING TOO DAT EFFECT........CAUSE I HAVE A SIMILAR PROBLEM MY CAR RUNS NICE WEN CEL LIGHT IS OFF THEN WEN IT KICKS ON ITS DA PERFECT CAR IN THE WORLD N I JUST CAHNGED MY MAIN RELAY.........ALSO ONE MORE THING TRY VERY HARD TOO KEEP INSIDE OF THAT CAR COOL CAUSE THE HEAT WILL DESTROY UR IGNITION RELAY CHECK THAT ALSO TRUST ME HEAT WILL DESTROY IT ALL!!!!!
Ya don't listen to this guy ^ and just start wasting money replacing shit.... If the cel isn't turning off then it probably isn't the main relay... but you need to follow this check list to rule it out
techauto.awardspace.com/ignition.html#
The main relay will throw a faulty code if it's bad but like I said I don't think that's the problem here... after you go through that checklist and you rule out the main relay, follow up with the code it's giving you and replace the barometric sensor you will need to swap the ecu... this isn't a hard thing to understand, don't just go replacing random shit start where the ecu is telling you the problem is.
