Help white smoke
Old Jul 6, 2010 | 11:33 AM
HonkeyDong's Avatar
Every dog has his day.
your piston rings "looked okay"? You must have good eyes...
Mattbuilt
AEM | Mugen | Skunk2 | Hasport | Hondata | Koni |Ground Control |
Old Jul 6, 2010 | 12:00 PM
snagger4banger's Avatar
like the pistons dont move side to side when the head is off
Old Jul 6, 2010 | 12:11 PM
JUSTINTHECOASTIE's Avatar
ima step out and say mutilpe valves are bent or broken...reason being the white smoke means its a water/cooling problem, so yeah...best of luck
Old Jul 6, 2010 | 12:19 PM
all of the valves were alright that i do know .. soo i think it might be something in the block that or i just got to chasnge the oil now becaus i did the head gasket
Old Jul 6, 2010 | 07:53 PM
kal727's Avatar
ok let me help this kid out its not smoking white its blue i know its oil this kid is a noob and most likely the rings are shot and its not because of an oil change
I LOVE MY EG8 AND CD7
Yank Krew Member #6
Old Jul 6, 2010 | 08:57 PM
nope
Old Jul 7, 2010 | 04:07 PM
  #17 (permalink)
ok...well ima try and make this cut and dry, remove head get pressure test and valve tested, have o-rings and piston heads, inspected and you should find your problem
