HELP car died and now wont start HELP
Old Jun 27, 2010 | 06:09 PM
SEEKERone's Avatar
Trialed for Treason
can anynody that is telling him that the distributor is the problem explain
why will the car not CRANK?
Old Jun 27, 2010 | 06:17 PM
eightwun3zfynest's Avatar
sleeper
it wont crank if ur not getting any spark from the dizzy
Old Jun 27, 2010 | 06:19 PM
efkidd525's Avatar
I do what I do
what would go bad in the dizzy for it not to crank?
TR "Old Skool EF" Member #179
Old Jun 27, 2010 | 06:43 PM
steezyteg's Avatar
2.2L vtakk
the dizzy makes the big spark from your spark plugs/spark plug wires thats why it has metal inside the wires and the cap, check to see if your rotor is screwed in because it could be lose also happened to me. if so just buy a new cap,rotor,and ignition coil should be one of those.
Old Jun 27, 2010 | 06:45 PM
steezyteg's Avatar
2.2L vtakk
could be many thing fuel pump,injectors, alottttt of things check your codes see if any codes are being thrown man you have to find something it could be we will never know unless you test your codes and see if its your spark,fuel,etc.
efkidd525's Avatar
I do what I do
i took the dizzy off and everything is fine from it nothing looks bad from what i know whoch isnt to much but it looks and feels fine
Old Jun 27, 2010 | 06:51 PM
  #17 (permalink)
efkidd525's Avatar
I do what I do
my ecu doesnt even have a light on it
Old Jun 27, 2010 | 06:56 PM
  #18 (permalink)
steezyteg's Avatar
2.2L vtakk
i dont know what to tell you man could be your fuel pump, do you hear your fuel pump click on when you turn the key to accesory?
Old Jun 27, 2010 | 06:59 PM
  #19 (permalink)
efkidd525's Avatar
I do what I do
no i heard my fan. dont know what a fuel pump would sound like
Old Jun 27, 2010 | 07:11 PM
  #20 (permalink)
steezyteg's Avatar
2.2L vtakk
it would be where your back seats are listane to a whiney sound if you hear it your fuel pump is good if not then you need a new one.
