What Shot of Nitrous on a stock 92 LS engine?????????
Old Jul 4, 2002 | 06:46 PM
chino5149's Avatar
Default What Shot of Nitrous on a stock 92 LS engine?????????
Ok, I finished my LS swap into my 89 si CRX about 3 weeks ago. And put a 55 shot of nitrous on it (ZEX KIT) Now my question is, what would be the most I could run on it safely with out tearing it up. The engine has just over 70,000 miles on it (92' B18A). Can I run the 65 or 75 shot? Or would I have to upgrade my fuel system? Any help would be appreciated!
Old Jul 4, 2002 | 07:51 PM
2qk4u's Avatar
i wouldnt run any amount without upgrades.
Old Jul 4, 2002 | 08:01 PM
chino5149's Avatar
Well.........what type of upgrades, fuel system, internal, window switch for the factory rev limiter, ignition upgrades, s-afc? Let me know where I need to start.
Old Jul 4, 2002 | 08:06 PM
cykociv's Avatar
Up and running
Start with your fuel...........
Then move to the ignition.
After that its up to you.
" Nitrous is like a hot chick with an STD, you wanna hit it, but you know what the consequences might be "
civicracer901's Avatar
B16ACRX
I wouldnt mees with that shit anyways too risky
WTB:A clean 90-91 civic hatchback. Red or black or white in color. Good exterior. Looking to spend around $2,000.
Old Jul 4, 2002 | 08:15 PM
chino5149's Avatar
I also replaced the plugs with bosch platinum +4's for the shorter ground electrodes, for faster heat dissipation so I don't get that glow plug effect to avoid detonation and retarded the timing like 2 degrees.
Old Jul 4, 2002 | 08:22 PM
chino5149's Avatar
What would you recommend for the fuel upgrades? s-afc, aftermarket fuel pressure riser, bigger fuel pump etc..........
Old Jul 4, 2002 | 09:35 PM
2qk4u's Avatar
fpr,adjustable cam gears,s-afc,MSD ignition.
2qk4u's Avatar
would get cam gears last though
