What Shot of Nitrous on a stock 92 LS engine?????????
What Does It All Mean?
Hot plugs? Cold Plugs? What does it all mean? Definition: The heat range of a spark plug is its ability to dissipate heat from the combustion chamber to the cylinder head. The heat range, or dissipation capability, of a spark plug depends primarily on the length of the insulator nose. The heat from the combustion is transferred from the insulator nose through the center electrode to the plug housing, and from there it goes to the cylinder head.
Hot Plug
A "hot plug" has a long insulator nose which exposes more surface area to the combustion gases. This keeps the plug temperature higher overall which is ideal for stop-start city driving conditions.
Cold Plug
A "cold plug" has a shorter insulator nose, which minimizes the amount of surface area exposed to the combustion gases. Cold plugs are typically used in racing conditions because of its ability to transfer heat out of the cylinder chamber quickly. Most turbo, supercharged and nitrous oxide applications use this type of plug because of the tremendous heat they generate. A colder plug can also minimize the risk of pre-ignition and detonation, however if the plug is to cold there is risk of fouling during extended periods of idling and low-speed operation.
Heat Dissipation
Heat Dissipation in a spark plug. Of the 100% heat generated from the combustion, 20% is absorbed by fresh air from the intake of the following stroke. 58% of the heat is absorbed by the walls of the cylinder head which hold the spark plug in place. Twenty percent is absorbed by the insulator and side walls of the plug, the remaining 2% being absorbed by the spark plug wires.
Hot Plug
Cold Plug
Heat Dissipation
In identical spark plugs, the differences from one heat range to the next is the ability to remove approximately 70°C to 100°C from the combustion chamber. A projected style spark plug firing temperature is increased by 10°C to 20°C.
Originally posted by "96Integ"
I would get two...two of the big bottles...
Yea, Your Deffinatly Going To Need 2 Big Ass Bottles After All, Didnt You Car Top Out At 140mph This Morning? h4h4h4h4h4
you could run a 45 safely stock with some plugwires and plugs (make sure you ignition system is up to par, ex. cap,rotor,coil ect.) to run a 55 safely ALL YOU NEED is a ignition system and copper ngks.
i suggest jacobs by far has some of the best products a little pricey though. i don't suggest ANY NITROUS SYSTEM, and if you are spraying use a fukin IGNITON SYSTEM.
(also don't use a dry system, zex sylinoids freeze up alot you should of got nx wet/dry system or something of that nature)
Anthony
(also don't use a dry system, zex sylinoids freeze up alot you should of got nx wet/dry system or something of that nature) Anthony
Drunmann Tuning's Scoob: 2.55 liter-6spd swapped Bugeye, fully built w/280 cams and a rotated Precision-6266
DD: 2010 MazdaSpeed3: Fully bolted and tuned
Drift Missile: S13 DOHC swap, welded diff = slidetastic
Bicycle: Kawi 636R.
Bicycle: Kawi 636R.
Originally posted by "2qk4u"
i doubt he was goin 140 in a ls.
mine wouldnt make it past 125, it was bone stock though.
