idle issue
Old Jun 6, 2010 | 03:50 PM
chico252's Avatar
Default idle issue
i need a lil help tr my hatch idle goes up n down
i cleaned da throttle body with brake cleaner n the sensor dat goes on the back of intake manifold wat it can it be???
Old Jun 6, 2010 | 03:56 PM
zhillz's Avatar
Porno Music Producer
the iacv might be bad.
Old Jun 6, 2010 | 04:02 PM
chico252's Avatar
thankz ima change it to see wat happens
Old Jun 6, 2010 | 04:42 PM
skylineowner's Avatar
iacv sounds to be the problems disconnect it an see if it stops
95 240SX SOLD
2004 DODGE SRT4 STOLEN
90 INTEGRA PARTED OUT
95 EG COUPE H22
chevy s10 dd
Old Jun 6, 2010 | 05:20 PM
custom240sx's Avatar
DC Crew Member #1
English please...
Check IACV and clean it
Reset Timing with timing light (the correct way)
Reset Idle with screw on throttle body
Reset Computer after all is done
Old Jun 6, 2010 | 06:17 PM
wow man ur most not have a life im trying to help him with a idea so if u got a problem lmk
95 240SX SOLD
95 EG COUPE H22
chevy s10 dd
Old Jun 6, 2010 | 07:11 PM
DC Crew Member #1
Wow calm down and realize I wasn't speaking to you lol
Old Jun 7, 2010 | 04:46 PM
JDMB18CYA's Avatar
Insured by Ruger.
yea man the common honda surge.i kno a guy out in south tampa that takes the tb and plugs one of the holes in it and on most engines it stops the surgeing.PM me for more info..and it actually works
Old Jun 8, 2010 | 12:47 PM
PorkFriedRicer's Avatar
Registered Poon Slayer
also check and recheck all vacuum lines..mine did the same because of a hole that wasnt even visible in the line
