my hatchback is now running
Old Jun 30, 2002 | 06:41 PM
chet's Avatar
All Aboard
i've never met flounder. what is he running?
Old Jul 2, 2002 | 12:19 PM
chet's Avatar
All Aboard
i'm getting a 5, 9, and 16.
this would be my map sensor, cyp sensor and something with my fuel injection.
*i'm using hasport's wiring conversion harness and everything else is stock..or at least i think it is...any ideas?
Old Jul 2, 2002 | 01:26 PM
cykociv's Avatar
Up and running
Default Try Racing Works
Try Racing Works. They might be able to help you. They couldn't help me but that is something different. They are located in Orlando.
407-699-9799 or 407-388-7734 / Open Weekdays 11am - 7pm EST
www.racingworks.com
" Nitrous is like a hot chick with an STD, you wanna hit it, but you know what the consequences might be "
Old Jul 2, 2002 | 04:29 PM
  #17 (permalink)
chet's Avatar
All Aboard
now i'm getting a 5 (map sensor) and a 9 which is first cylinder position.
it appears as though my map sensor is not wired at all. on the car side of the harness there aren't any wires leading to the ecu...which is why i'm nearly positive its the map sensor that i need to wire. now my question is this, shouldn't my dx civic hatchback come with a map sensor? the car was bone stock when i purchased it and the harness wasn't tampered with to the best of my knowledge.
so, if i have to wire in the map sensor then it seems like everything should work...
Old Jul 3, 2002 | 05:57 AM
  #19 (permalink)
ghuey's Avatar
member
Chet your intake should be there today,I tracked your package and its "out for delivery"...
~Guy Huey
AE
Old Jul 3, 2002 | 09:00 AM
  #20 (permalink)
chet's Avatar
All Aboard
although everyone is tired of me posting...this is the latest on my car. it seems like vtec engages after the car is warm and i shut it off, then back on...and after that vtec engages and the car becomes really fast.
i'm not getting a 5, which is what i'd expect because my map sensor doesn't seem to be plugged in. instead i'm still getting a 9.
any suggestions would be great...and also, where on the car side harness was the map sensor plugged into on a stock 1992 dx civic...and what is the plug position for the map sensor on a p30 ecu.
thanks.
guy...my intake is here, now i just have to find it...for some reason the postal service can't deliver to my house so they just drop it off at the town hall...anyway, i'll let you know how this works out when i locate it.
