1.5 Sohc Thoughts
vx head?? are you fucking serious?? the vx is a vtec-e motor... the e stands for ECONOMY!
My 1.5 right is pretty fast for what it is. Maybe i have some carbon build-up on the pistons causeing higher compression
Im not sure but it runs pretty good
-Mick
93 DX Hatch
-Mick
93 DX Hatch
Guest
Posts: n/a
look man, unless you have somthing to prove, dont try to build sohc, no matter what you will end up putting tons of money in it and will never be as happy as you were if you just broke down and got b16/18, look at starting points, the cx motor has like 90hp (i think) b16 has atleast 160 a cx with around 200hp is not nearly reialble as dohc with same, i am not flaming just suggesting my thoughts and i think hondata is last thing you need to worry about, and in that case i suggest a chiped ecu or haltech! good luck, eric
I would love to go to B16 but I cant find out what I need to do a basic swap with a 93 DX Hatch. So I figured just stay with the D15. If maybe someone could give me the low down on the basic swap like hidden things that pop up and just give me some details i would probably go that route it is just hard find the answer that I want
-Mick
93 DX Hatch
-Mick
93 DX Hatch
well if u got bseries in your hatch ur need a mount kit for a b16a1(i was told by someone here the 90-93 teg mounts&brackets worked perfectly but i never tried to use them so i wouldnt know...i sold my swap and hatch before i was finished)...not sure about the other b16's since some del sols came stock with one...adjustable shift linkage unless u wanna make ur own...time to wire if its not obd1 ecu...if u get obd2 there are conversion kits...one at AE for obd1-obd2...axles...and set aside some time for wiring...might be simpler to get rpm activated switch for your vtec(if u go that route)... theres more then likely alot more stuff you need to know...but ill just shut up since im prolly gunna get insulted about this post too...
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
a b16 will go right into your 93 hatch, you just use all the delsol mounts and the axles. all of the wiring will plug right in except you will have to run a wire for vtec and the knock sensor wire. for the money the b16 is the best swap to go with, its just that they dont have a lot of torque so some people wind up putting in a 1.8 block down the road
sorry but they did make on obd0 b16 the wiring wont just "plug up" believe me...ive tried
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
im looking at a this motor http://www.hondamotorsonline.com/shop/sc2000search.cgi?what=page&item=B16A%20Sir%202 %20Complete%20Change%20Over what else do I need and where can I find it at?
-Mick
93 DX Hatch
-Mick
93 DX Hatch
